Автор Тема: Расшифровка ВИН кода  (Прочитано 166404 раз)
Оффлайн Kaiser
  • зачОООтка: +71/-0
Re: Расшифровка ВИН кода
« Ответ #435 : Апреля 28, 2017, 12:05:56 am »
Будьте добры,посмотрите:3GNFK16R6VG118919 .
3:   3: MEXICAN BUILT
G:   G: GENERAL MOTORS
N:   N: CHEV MPV
F:   F: GVWR RANGE 7001-8000 BRAKE SYSTEM - HYD
K:   K: CONVENTIONAL CAB GMT 400 4 X 4
1:   1: 1/2 TON
6:   6: ALL PURPOSE VEHICLE
R:   R: ENG OPT - L31 DISPL(L) - 5.7 CYL - V8 FUEL SYS - CPI
6:   Check digit
V:   V: 1997 MODEL YEAR
G:   G: SILAO MEXICO
Код модели кузова:   CK1090
Модельный год:   1997
Дата производства:   20.11.1996
132:  TRIM COMBINATION,LEATHER,GRAY,(132)
1SC:  PACKAGE-OPTION 03,(1SC)
1SZ:  PACKAGE OPTION-,(1SZ)
6GF:  SPRING COMPTR SELECT FRT LH,SUSP(6GF)
7GF:  SPRING COMPTR SELECT FRT RH,SUSP(7GF)
96U:  EXTERIOR COLOR,PRIMARY,(96U)
A31:  WINDOW,ELECTRIC OPERATED,SIDE,ELEC SI WDO(A31)
A95:  SEAT,FRONT BUCKET,DRIVER,PASSENGER,HIGH BACK RECLINING,FRT HIGH
AG9:  ADJUSTER,SEAT,6-WAY POWER,6-WAY PWR ST ADJR(AG9)
AJ1:  GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW),DEEP TIN
AS3:  SEAT,REAR UTILITY,R/SEAT(AS3)
AT5:  SEAT,RR CENTER FOLDING,RR CTR FLDG SEAT(AT5)
AU0:  LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM),REMOTE ENTRY LK
AU3:  LOCK,SIDE DOOR,ELECTRIC,ELEC S/D LK(AU3)
AXP:  VIN IDENT POSITION, MULTI- PURPOSE VEHICLE,MULTI-PURPOSE VEHICLE
B33:  COVERING,FLOOR MATS,REAR AUXILIARY,RR AUX FLR MATS(B33)
B37:  COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY,FRT/RR AUX FLR MATS
B85:  ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING,BELT RVL MLDG(B85)
B96:  ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BRIGHT),WHL OPG MLD
BVE:  STEPS RUNNINGBOARD, SIDE,RUNNINGBOARD SIDE STEPS(BVE)
C36:  HEATER,AUXILIARY,AUX HTR,RR(C36)
C49:  DEFOGGER,REAR WINDOW,ELECTRIC,ELEC RR WDO DEFG(C49)
C60:  AIR CONDITIONER,FRONT,MANUAL CONTROLS,A/C MAN CONT(C60)
C69:  AIR CONDITIONER,RR AUX,RR AUX A/C(C69)
C6A:  GVW RATING(7300 LBS),7300 LB GVWR(C6A)
D48:  MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR,ELEC R/CON P
D55:  CONSOLE,FRONT COMPARTMENT FLOOR,F/CMPT FLR CNSL(D55)
DK6:  CONSOLE,ROOF,RF CNSL(DK6)
FE9:  FEDERAL EMISSION CERTIFICATION,FED EMIS(FE9)
FK2:  ARM,TORSION BAR,SPRING ADJUST,LH,TORS BAR SPR ADJ ARM(FK2)
FK3:  ARM,TORSION BAR,SPRING ADJUST,RH,TORS BAR SPR ADJ ARM(FK3)
G80:  AXLE,REAR,POSITRACTION,LIMITED SLIP,POSITRACTION L/SLIP R/AXL(G8
GU6:  AXLE,REAR,3.42 RATIO,3.42R(GU6)
JB6:  BRAKE SYSTEM,VACUUM POWER DISC,DRUM,VACUUM PWR BRK SYS(JB6)
K34:  CRUISE CONTROL,AUTOMATIC,ELECTRONIC,CRCONT(K34)
K68:  GENERATOR,105 AMPERE,105 AMP(K68)
KC4:  COOLING SYSTEM,ENGINE OIL,ENG OIL CLG(KC4)
KNP:  COOLING SYSTEM,TRANSMISSION,HEAVY DUTY,HVY DUTY TRANS CLG SYS(KN
L31:  ENGINE,GAS,8 CYL,5.7L,CPI,5.7R(L31)
M30:  TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC,4-SPD A/TRANS(M3
MSL:  PLANT CODE SILAO, MEXICO, GM DE MEXICO,SILAO,MEXICO PLANT(MSL)
N33:  STEERING COLUMN,TILT TYPE,TILT STRG COL(N33)
NA1:  EMISSION SYSTEM,LESS THAN 8500 LB GVW,EMIS SYS(UNDER 8500 LB GVW
NP5:  STEERING WHEEL,LEATHER WRAPPED,LEATHER WRAPPED STRG WHL(NP5)
NRQ:  EXHAUST,CLOSE COUPLED,CLOSE COUPLED EXH(NRQ)
NY1:  SHIELD,FUEL TANK,F/TANK SHLD(NY1)
NZZ:  PACKAGE,OFF ROAD SKID PLATE,SPORT,SKID PLT PKG(NZZ)
QGA:  TIRE ALL P245/75R16 BW R/PE ST TL AT 109S,TIRE(QGA)
UP0:  RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, A
V22:  GRILLE,RADIATOR(CHROME),CHROME GRL(V22)
V54:  CARRIER,ROOF LUGGAGE(PAINTED),PAINTED RF LUGG CARR(V54)
V73:  VEHICLE STATEMENT - US/CANADA,US/CANADA VEHICLE STATEMENT(V73)
VGC:  PROTECTOR FILM, PAINT ETCH PREVENTIVE,PAINT PROTECTOR FILM(VGC)
VK3:  LICENSE PLATE,FRONT MOUNTING PACKAGE,FRT LIC PLT MTG PKG(VK3)
VR4:  TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM),EQLZR HITCH(VR4)
X88:  CONVERSION CHEVROLET,CHEVROLET(X88)
XGA:  TIRE FRONT P245/75R16 BW R/PE ST TL AT 109S,TIRE(XGA)
YD3:  AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE,FRT AXLE(YD3)
YD6:  SPRING,REAR(BASE EQUIPMENT),RR SPRING(YD6)
YE9:  CONVENIENCE PKG COMFORT & DECOR LEVEL #3,COMFORT & CONVENIENCE P
YGA:  TIRE REAR P245/75R16 BW R/PE ST TL AT 109S,TIRE(YGA)
Z82:  TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH),PROVISION FOR HD T
ZGA:  TIRE SPARE P245/75R16 BW R/PE ST TL AT 109S,SPARE TIRE(ZGA)
ZQ3:  DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION),DRVR CONVENI
ZW9:  BASE BODY OR CHASSIS,BASE BODY/CHAS(ZW9)
ZY1:  COLOR COMBINATION SOLID,SOLID PAINT COMBO(ZY1)
GMC Jimmy '97 4,3 AWD
Chevy Silverado '92 7,4 4х4
Оффлайн медвед
« Ответ #436 : Апреля 28, 2017, 12:17:25 am »
Спасибо Вам большое!
Dodge Caravan 2001
Оффлайн EVGEN[40RUS]
  • зачОООтка: +19/-0
  • +7(96О)519-7З-З2
« Ответ #437 : Апреля 28, 2017, 10:34:07 am »
1GNEK13T3YJ201190 что по нему хорошего скажете?
Chevrolet tahoe 2001г.
Freightliner Century 99 г. DD 12.7 non EGR
« Ответ #438 : Апреля 28, 2017, 10:49:31 am »
Клановская Таха, передается только между своими. ;D
Оффлайн verner
  • зачОООтка: +231/-10
  • GMC SAFARI 1994г.в
« Ответ #439 : Апреля 28, 2017, 11:58:36 am »
Парни ну и мне помогите с расшифровкой VIN
1GKDM19ZXRB517017    Safari
1GNDM15Z6MB153986     Astro
Оффлайн Roadster
  • зачОООтка: +152/-3
« Ответ #440 : Апреля 28, 2017, 12:08:11 pm »
"маленькая подсказка" на сайте usa-auto.ru можно зарегистрироваться и совершенно бесплатно получать расшифровки вина
Оффлайн Василий Алибабаевич
  • Авто: Blazer 2DR
« Ответ #441 : Апреля 28, 2017, 12:08:48 pm »
© 2017 General Motors
VIN: 1GKDM19ZXRB517017
Build Date 09-Nov-1993
Code Description
1 U.S. BUILT
G SUZUKI
G GENERAL MOTORS
K GMC MPV
D GVWR RANGE 5001-6000 BRAKE SYSTEM - HYD BUICK & CHEV. COMMERCIAL BODY/CHASSIS
M SMALL VAN 4 X 2 CHEVY VAN SPORT VAN AND ASTRO GMC VANDURA RALLY & SAFARI
1 1/2 TON
9 EXTENDED CAB/VAN
Z ENG OPT - LB4 DISPL(L) - 4.3 CYL - V6 FUEL SYS - TBI DIV - C,H,T PROD IN - U.S.
X CHECK DIGIT
R 1994 MODEL YEAR
B BALTIMORE (T&B) MD
517017   SERIAL NUMBER
RPO
Code Description
13G TRIM COMBINATION CLOTH,LT GRAY
13I INTERIOR TRIM,LT GRAYINTERIOR TRIM,LT SMOKE GRAY
15P WHEEL COLOR,SILVER METALLIC
1SB PACKAGE-OPTION 02
1SZ PACKAGE OPTION-
34U EXTERIOR COLOR,PRIMARY,LT TEAL MET
6PS COMPONENT FRT LH COMPTR SEL SUSP(6PS)
7PS COMPONENT FRT RH COMPTR SEL SUSP(7PS)
A07 WINDOW,BODY GLASS
A08 WINDOW,BODY GLASS,RH SIDE
A31 WINDOW,ELECTRIC OPERATED,SIDE
A78 ADJUSTER,FRT ST BK MAN RECLINING,PASSENGER AND DRIVER
AQ4 SEAT,REAR
AU3 LOCK,SIDE DOOR,ELECTRIC
AV5 FRONT HIGH BACK BUCKET SEAT
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
B37 COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY
B88 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(CUSTOM)
BAL PLANT CODE BALTIMORE, MD, GM T&B
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS
C6M GVW RATING 5,950 LBS/2,700 KG
D44 MIRROR,OUTSIDE,BELOW EYELINE(PAINTED)
FE9 FEDERAL EMISSION CERTIFICATION
FLT FLEET PROCESSING OPTION
GU5 AXLE,REAR,3.23 RATIO
JM4 BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC
K60 GENERATOR,100 AMPERE
LB4 ENGINE,(4.3Z),V6,EFI
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)
N33 STEERING COLUMN,TILT TYPE
N46 STEERING WHEEL,4-SPOKE,VINYL
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS
QCU TIRE ALL P215/75R15/N BL R/PE ST TL ALS
R6K CONTROL SALES ITEM NO. 11
R9S CONTROL - SALES ITEM NO. 93
TFD SALES INCENTIVE
TL1 GRILLE,SPECIAL
U73 ANTENNA,FIXED
UM7 RADIO,AM/FM STEREO,ETR,CLOCK
UQ1 RADIO,PROVISIONS FOR STEREO
V73 VEHICLE STATEMENT - US/CANADA
VE6 STRIP,FRONT AND REAR BUMPER IMPACT(COLOR)
VQ2 FLEET PROGRAM - DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE
VX7 FLEET PROGRAM-CASH ON DELIVERY DAILY RENTAL
VXS LABEL COMPLETE VEHICLE
XCU TIRE FRONT P215/75R15/N BL R/PE ST TL ALS (9591058)
YCU TIRE REAR P215/75R15/N BL R/PE ST TL ALS (9591058)
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5 SPRING,FRONT(BASE EQUIPMENT)
YD6 SPRING,REAR(BASE EQUIPMENT)
Z88 GMC TRUCK
ZJ7 WHEEL,HUB CAP AND TRIM RING(SPECIAL)
ZL7
ZP8 SEATING ARRANGEMENT,EIGHT PASSENGER
ZQ2 DRIVER CONVENIENCE PACKAGE
ZQ3 DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION)
ZW6 GLASS PACKAGE,COMPLETE BODY
ZW9 BASE BODY OR CHASSIS
ZY1 COLOR COMBINATION SOLID
VCVS
Code Description
10 Engine Assembly BCT TCK
35 Steering column - SIR System Only BCT FDC
36 Buffer Assembly - Vehicle Speed Sensor BCT CBL
61 Transmission BCT 4MJD
65 Rear Axle Assembly BCT UTL
66 Right Front Hub Assembly BCT WHR
67 Left Front Hub Assembly BCT WHR
86 Powertrain/Vehicle Control Module (PCM/VCM) BCT BJLA
92 Brake Pressure Modulator PNT 7618
AB SIR Module Assembly - Steering Wheel Inflator BCT 2407
AD SIR Sensor Assembly - Forward PNT 3515
AE SIR Sensor Assembly - Arming PNT 8875
AI SIR Module Assembly - Diagnostic Energy Reserve (DERM) PNT 3440
VIN: 1GNDM15Z6MB153986
Build Date  03-Jan-1991
Code Description
1 U.S. BUILT
G GENERAL MOTORS
G SUZUKI
N CHEV APV
1 1/2 TON
5 VAN
Z DISPL(L) - 4.3 CYL - V6 FUEL SYS - FI DIV - C,T PROD IN - U.S.
6 CHECK DIGIT
M 1991 MODEL YEAR
B PUPYONG KOR
B LANSING (GM33) MI
153986   SERIAL NUMBER
RPO
Code Description
10U EXTERIOR COLOR,ARTIC WHITEEXTERIOR COLOR,PRIMARY
15P WHEEL COLOR,MEDIUM SLATE GRAYWHEEL COLOR,SILVER METALLIC
47I INTERIOR TRIM,DARK RED
47W TRIM COMBINATION,VINYL,DARK RED
6DA SPRING COMPTR SELECT FRT LH
7DA SPRING COMPTR SELECT FRT RH
A18 WINDOW,SWING OUT GLASS,REAR DOOR
AL4 SEAT,REAR,BUCKET
ANL PACKAGE,AIR DEFLECTOR AND FOG LAMPS
AQ4 SEAT,REAR
C36 HEATER,AUXILIARY
C5G GVW RATING(5600 LBS)
C95 LAMP,INTERIOR,ROOF COURTESY AND DUAL READING
D64 MIRROR,INSIDE,RH VISOR VANITY,ILLUMINATED
EXP EXPORT - I.E.S. EXPORT I.E.S.
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP
GU6 AXLE,REAR,3.42 RATIO
KC4 COOLING SYSTEM,ENGINE OIL
MAE MARKETING AREA EUROPE(EXPORT)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60)
N31 STEERING WHEEL(CUSTOM)
N40 STEERING,HYDRAULIC(NON-VARIABLE)
QCF TIRE ALL P205/75R15/N RWL R/PE ST TL ALS
SLL SALES PROCESSING-SOLD ORDERS
TFD SALES INCENTIVE
TL1 GRILLE,SPECIAL
TR9 LAMP GROUP,COURTESY
U18 SPEEDOMETER,INSTRUMENT,KILOMETER(EXPORT)
U52 CLUSTER,INSTRUMENT(ELECTRONIC)
U73 ANTENNA,FIXED
UL2 RADIO FREQUENCY(EUROPEAN)
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK
V02 RADIATOR,HEAVY DUTY,INCLUDES HEAVY DUTY TRANSMISSION OIL COOLER
V54 CARRIER,ROOF LUGGAGE(PAINTED)
V78 VEHICLE STATEMENT(DELETE)(EXPORT)
VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL
VE5 STRIP,FRONT AND REAR BUMPER IMPACT(BLACK)
X88 MARKET BRAND CHEVROLET
XCF
YC6 DECOR PACKAGE/CL/SLE,#6(LUXURY)
YCF
ZP7 SEATING ARRANGEMENT,SEVEN PASSENGER
VCVS
Code Description
10 Engine Assembly BCT FLD
36 Buffer Assembly - Vehicle Speed Sensor BCT AGM
61 Transmission BCT 1MJM
65 Rear Axle Assembly BCT SGJ
66 Right Front Hub Assembly BCT WCN
67 Left Front Hub Assembly BCT WCN
86 Powertrain/Vehicle Control Module (PCM/VCM) BCT AUMH
92 Brake Pressure Modulator PNT 9174
К верхней крышке дна штампованного чугунного люка двумя болтами приварено трехугольное алюминиевое отверстие диаметром 3 на 4 мм
  • Авто: Blazer 2DR
« Ответ #442 : Апреля 28, 2017, 12:12:36 pm »
Сравниваем...
VIN: 1GNEK13T3YJ201190
Build Date  27-Jun-2000
Code Description
1 U.S. BUILT
G GENERAL MOTORS
N CHEV MPV
E GVWR RANGE 6001-7000 BRAKE SYSTEM - HYD CADILLAC COMMERCIAL BODY/CHASSIS
K1 ESCALADE 4 X 4 1500 (1/2 TON)
K1 FULL SIZE TRUCK 4 X 4, 1500 (1/2 TON)
3 FOUR-DOOR CAB/UTILITY (INCLUDES BLAZER,JIMMY,BRAVADA, ENVOY,TRACKER,FULL SIZE
YUKON,TAHOE,DENALI,ESCALADE, AND CREW CAB)
3 FOUR-DOOR ALL PURPOSE VEHICLE (TRANSPORT,VENTURE, SILHOUETTE)
T ENG OPT - LM7 DISPL(L) - 5.3 CYL - V8 FUEL SYS - MFI PROD IN - U.S.
3 CHECK DIGIT
Y 2000 MODEL YEAR
J JANESVILLE (T&B) WI
201190  SERIAL NUMBER
RPO
Code Description
12D TRIM COMBINATION CLOTH, GRAPHITE
12I INTERIOR TRIM GRAPHITE
1SZ PACKAGE OPTION-
41U EXTERIOR COLOR,PRIMARY,BLACK
6XM SPRING COMPTR SELECT FRT LH
7XM COMPONENT FRT RH COMPUTER SEL SUSP (7XM)
A31 WINDOW,ELECTRIC OPERATED,SIDEWINDOW,POWER OPERATED,ALL DOORS
A95 SEAT,FRONT BUCKET,DRIVER,PASSENGER,HIGH BACK RECLINING
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONALADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW)
AT5 SEAT,RR CENTER FOLDING
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM)
B30 CARPET,FLOOR AND WHEELHOUSE
B39 CARPET,LOAD FLOOR
B58 COVERING,FLOOR MATS,FRONT AND REAR,CARPETED INSERT
B85 ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING
C49 DEFOGGER,REAR WINDOW,ELECTRIC
C5U GVW RATING(6800 LBS)
C69 AIR CONDITIONER,RR AUX
D07 CONSOLE,FRONT COMPARTMENT FLOOR(CUSTOM)
DF5 MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY
DH2 MIRROR,INSIDE, ILLUMINATED,LH & RH,WITH DUAL SUNSHADE
DK7 CONSOLE ROOF INTERIOR,CUSTOM,COMPASS & OUTSIDE TEMP
DR2 MIRROR,OUTSIDE,LH & RH, REMOTE CONTROL,ELECTRIC, MANUAL FOLDING HEATED
EVA TEST DVT, EVAP EMISSION REQUIREMENT
FF6 ARM,TORSION BAR SPRING ADJUST,LH
FF7 ARM,TORSION BAR SPRING ADJUST,RH
GT4 AXLE,REAR,3.73 RATIO
JAN PLANT CODE - JANESVILLE, WI, BOC
JC5 BRAKE VAC POWER, 4 WHL DISC, 7,200 LBS
K47 AIR CLEANER HIGH CAPACITY
KG8 GENERATOR 130 AMP
KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY
LM7 ENGINE GAS, 8 CYL, 5.3L, MFI
NF2 EMISSION SYSTEM,FEDERAL,TIER 1
NG1 EMISSION CERTIFICATION,GEOGRAPHICALLY RESTRICTED CERTIFICATION
NP5 STEERING WHEEL,LEATHER WRAPPED
NP8 TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL
NZZ PACKAGE,OFF ROAD SKID PLATE,SPORT
PF4 WHEEL,16X7(ALUMINUM)
QNL TIRE ALL P245/75R16 WOL R/PE ST TL ALS 109S
R9I CONTROL - SALES ITEM NO. 84
R9K CONTROL - SALES ITEM NO. 86
SLM SALES PROCESSING-STOCK ORDERS
T96 LAMP,FRONT FOG
UG1 OPENER GARAGE DOOR, UNIVERSAL
UP0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, CLOCK, ETR.
UQ3 SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO
UY7 TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS
V22 GRILLE,RADIATOR(CHROME)
VB3 BUMPER,REAR STEP,INCLUDES IMPACT STRIP(CHROME)
VG3 STRIP,FRONT BUMPER IMPACT
VR4 TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM)
XNL TIRE FRONT P245/75R16 WOL R/PE ST TL ALS 109S
YE9 SILVERADO/SIERRA CLASSIC/SLE PACKAGE
YNL TIRE REAR P245/75R16 WOL R/PE ST TL ALS 109S
Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH)
ZM9 SALES PACKAGE COMFORT AND CONVIENCE
ZNL TIRE SPARE P245/75R16 WOL R/PE ST TL ALS 109S
ZQ1 CHASSIS PACKAGE SMOOTH RIDE
VCVS
Code Description
10 Engine Assembly BCT FHB
35 Steering column - SIR System Only BCT TKW
60 Transfer Case (4 Wheel Drive) BCT SM
61 Transmission BCT 0KCD
63 Front Axle Or Front Cradle With Front Hub Assemblies P/K/G Trucks, Other BCT US9
65 Rear Axle Assembly BCT CH5
86 Powertrain/Vehicle Control Module (PCM/VCM) BCT CYCB
87 Body Control Module PNT 7155
92 Brake Pressure Modulator PNT 2794
AB SIR Module Assembly - Steering Wheel Inflator BCT 7245
AD SIR Sensor Assembly - Forward PNT 6305
AL SIR Module Assembly - Passenger Inflator BCT 2834
AS SIR Sensing Diagnostic Module (SDM) PNT 3179
AT SIR Right Side-Impact Sensing Module PNT 8629
AU SIR Left Side-Impact Sensing Module PNT 8629
CB Sequence Numbers (Flex) Body Assembly Area or Energy Storage System
(Veh/Year specific)
T 1ZZ
CF Sequence Numbers (Flex) Paint Process Area T 1WW
CG Sequence Numbers (Flex) Paint Process Area T 1PP
CP Sequence Numbers (Flex) General Assembly Area T 1GG
Оффлайн verner
« Ответ #443 : Апреля 28, 2017, 12:32:58 pm »
Огромное спасибо!
Оффлайн DocVlad
  • Глушитель
  • Авто: Chevrolet Blazer
« Ответ #444 : Мая 11, 2017, 09:25:54 pm »
Здравствуйте. Расшифруйте, пожалуйста VIN: X4F116DWWWC917220 Елабуга. И еще, может кто подскажет, где скачать программу для поиска запчастей по вину. Не могу найти. Говорят, есть на английском от 2006 года... :)
« Ответ #445 : Мая 12, 2017, 08:36:48 am »
  • елабужксий vin не расшифровывается
    Оффлайн медвед
    « Ответ #446 : Мая 12, 2017, 09:50:24 am »
     Машина у меня по вину Модельный год:   1997
    Номера запчастей попадаются разные 96 и 97 годов. :(Не понятно,что покупать.Кто сталкивался с подобным поможите :)
    Dodge Caravan 2001
    Оффлайн Борисъ
    • зачОООтка: +31/-0
    « Ответ #447 : Мая 12, 2017, 02:46:27 pm »
    Модельный год начинается с середины предыдущего календарного. Запчасти заказывать строго по вину.
    Оффлайн медвед
    « Ответ #448 : Мая 12, 2017, 04:34:47 pm »
    Благодарю.
    Dodge Caravan 2001
    « Ответ #449 : Мая 12, 2017, 04:56:22 pm »
  • заказывай на 97...
    до 2000 г.  на американские машины ВИН не всегда указывает на конкретную деталь.
    Например, трос ручника может вылезти 5 номеров - выберите свой :)
    До 90 г ваще 50\50 что покажет правильно
