Автор Тема: Греемся в пробках...  (Прочитано 4113 раз)
Оффлайн lexxUz
« : Июня 17, 2017, 01:26:20 am »
Доброго времени суток. Тихон 2006 года рождения уроженец г.Калининград. В пробках температура по прибору поднимается на 2-3 деления после 100 градусов так около 3-5минут держится за тем падает до 98... Так и должно быть или надо лечить? Если лечить то что?
SsangYong Musso 1998, Hundai Starex 2001, TLC 80, Chevrolet Tahoe 2006, Cadillac Escalade ESV 2005...
Оффлайн Якутик
  • зачОООтка: +48/-5
Re: Греемся в пробках...
« Ответ #1 : Июня 17, 2017, 01:45:40 am »
2006 Chevy Truck Tahoe 4WD V8-5.3L VIN T       Copyright © 2012, ALLDATA
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Important:  The right and left cooling fan connectors are interchangeable. When servicing the fans be sure that the connectors are plugged into the correct fan.
The PCM commands the low speed cooling fans ON under the following conditions:
^Engine coolant temperature exceeds approximately 94.5°C (202°F).
^A/C refrigerant pressure exceeds 1447 kPa (210 psi) .
^After the vehicle is shut OFF if the engine coolant temperature at key-off is greater than 101°C (214°F) the low speed fans will run for a minimum of 60 seconds After 60 seconds, if the coolant temperature drops below 101°C (214°F) the fans will shut OFF. The fans will automatically shut OFF after 3 min. regardless of coolant temperature.
The PCM commands the high speed fans ON under the following conditions:
^Engine coolant temperature exceeds approximately 104.25°C (220°F).
^A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
^When certain DTCs set.
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed if required. This insures idle stability by preventing the fans from cycling between high and low speed.
Tahoe 05
Оффлайн Якутик
  • зачОООтка: +48/-5
« Ответ #2 : Июня 17, 2017, 01:50:50 am »
и заехать на мойку помыть радиаторы
Tahoe 05
