Автор Тема: Самодиагностика GMC suburban.1995 TBI как делать кто знает?  (Прочитано 5169 раз)
Оффлайн Maks suburban
Вопрос собственно в шапке.может кто знает как делать самодиагностику на наших монстрах?мотор  TBI 5,7.
Оффлайн pnp2000
  • зачОООтка: +20/-0
  • Авто: Lexus RX400h
Вроде надо поставить перемычку между А и В
а дальше считать мигания чека
12- diagnostic mode
13- 02 sensor or circuit
14- coolant sensor or circuit/ high temp indicated
15- coolant sensor or circuit/ low temp indicated
16- system voltage out of range
19- crankshaft position sensor or circuit
21- throttle position sensor or circuit- voltage high
22- throttle position sensor or circuit- voltage low
23- mixture control (m/c) solenoid or circuit (carbureted models)
23- manifold air temperature (mat) sensor or circuit (1990 and earlier models) 23- intake air temperature (iat) sensor circuit (fuel-injected models)
24- vehicle speed sensor (vss) or circuit
25- manifold air temperature (mat) sensor or circuit - high temperature indicated (1990 and earlier models)
25- intake air temperature (iat) sensor or circuit - high temperature indicated (1991 and later models)
26- quad driver module circuit
27- quad driver module circuit
28- quad driver module circuit
29- quad driver module circuit
31- park/neutral position (pnp) switch circuit
32- baro sensor or circuit (carbureted models)
32- egr circuit (fuel-injected models)
33- manifold absolute pressure (map sensor signal voltage high
33- mass air flow (maf) sensor or circuit - excessive airflow indicated
34- manifold absolute pressure (map) sensor signal voltage low
34- mass air flow (maf) sensor signal - low airflow indicated
35- idle speed control (isc) switch or circuit (shorted) (carbureted models)
35- idle air control (iac) valve/ circuit
38- brake switch circuit
39- torque converter clutch (tcc) circuit
41- no distributor signals to ecm, or faulty ignition module ( carbed models)
41- cylinders select error- mem-cal or ecm problem ( fuel-injected models
41- cam sensor circuit (3.8 engine)
42- bypass or electronic spark timing (est) circuit
43- low voltage at ecm terminal l (carbureted models)
43- knock sensor circuit
44- oxygen sensor or circuit - lean exhaust detected
45- oxygen sensor or circuit - rich exhaust detected
46- power steering pressure switch circuit
48- misfire diagnosis
51- prom, mem-cal or ecm problem
52- calpak or ecm problem
53- egr fault (carbureted models only)
53- system over-voltage (ecm over 17.7 volts)
54- mixture control (m/c) solenoid or circuit (carbureted models)
54- fuel pump circuit (1986 and later models)
55- oxygen sensor circuit or ecm
55- fuel lean monitor (2.2l engine)
61- oxygen sensor signal faulty (possible contaminated sensor)
62- transaxle gear switch signal circuits
63- manifold absolute pressure (map) sensor voltage high (low vacuum detected)
64- manifold absolute pressure (map) sensor voltage low (high vacuum detected)
66- pressure sensor or circuit air conditioning
12- diagnostic mode
спасибо огромное,попробую.
Оффлайн александр-док
  • москва СВАО.
  • Авто: ШЕВИ ТАХО 1995 г.в. 5,7 TBI
по результату отпишись. 8)
шеви тахо    1995г.в. 4х4 TBI 5.7
